Discuss 2 conductors in the same Wago connector hole in the UK Electrical Forum area at ElectriciansForums.net
I've just watched a video on youtube about installing a bathroom extractor fan off of the light switch.
In it the guy says how much easier this is when you use Wago connector blocks rather than a ceiling rose (about 7 and a half minutes in). He's using Wago 3-way lever connector 222 blocks, but of course 3 of the blocks need 4 connections, so he's shoved 2 conductors into the same hole.
Is this safe / ok? I guess 5-way connectors wouldn't fit in the box, and (as far as I can tell) they don't sell 4-way connectors.
Any advice much appreciated.
I certainly would never do that. It doesn't take many brain cells to imagine that there is a high chance of a poor quality connection doing this, especially with solid core conductors as the dipstick in the video has done.
On a side note, anybody using wire strippers isn't a proper sparks :D
Definitely agree with this. If it's got two slots, it's meant for two conductors. Although he makes it look as if it's got a good connection. I don't think it really is.
I've often wonder myself, as I couldn't find any info on that subject on the WAGO site. I have experimented, putting two conductors into the same connection, tugging one or either conductor, can result in one coming loose from the terminal. I guess any slight discrepancy in the same conductor size can prevent a secure clamp of said conductor.
Much better to use the one conductor into single clamp connection, and use a Wago XL box to accommodate the larger clamp connectors.
Of course you wouldn't think of twisting two conductors together and use one clamp connection, would you :eek:
Thanks for the responses - I thought it was probably not a good idea trying to fit 2 into the same slot.
So you're going to need 3 x 4-way connector and 1 x 3-way connector, which will take up quite a bit of space. What kind of box would accommodate all of that?
If it's loop in (L/I), loop out (L/O), switch (S), light (L) and fan (F), you're going to need (these are standard size push connectors):-
1 x 6w (CPC - L/I, L/O, S, L, F)
3 x 4W (P/L - L/I, L/O, S, F) (S/L - S, L, F) (N - L/I, L/O, L, F)
They will fit quite comfortably in a standard Wagobox.
Reply to 2 conductors in the same Wago connector hole in the UK Electrical Forum area at ElectriciansForums.net
Hi I've been planning to fit an outdoor junction box at the front of my house to hide a large brickwork hole and properly house the wiring...
Hi all, Disclaimer: I'm not an electrician and have very basic knowledge of electrical installation. We've been putting in a new kitchen into an...
  • Locked
5K
Hi, My son has just (last week) had a rewire done on his house in Leyland. He has just bought the house but a "domino" type consumer unit was...
12K
