Discuss 2 hours to swap a light fittring in the Australia area at ElectriciansForums.net
telectrix
Mentor
as title. this morning. one of these fancy crystal bauble things. about 36 danglies to hang on the bloody thing. impossible to thread them on once it's up, so put them all on, then had all the weight of it to wire up. instead of a centre fixing to the ceiling bracket, it had to have 4 pins, on sliding slots. tighten them up and the holes won't line up. leave 'em slack and can't tighten the nuts. finally gets it up only to find that all the lights on the circuit don't work. down it comes to find one of the neutral terminations has snapped off due to struggling to get the bloody thing mounted. finally fixed after much swearing. the only good bit is customer wants me to quote for replacing rewireable CU.
I hate the phone call that says can you come and change a light fitting for one I have brought. A simple job I used to think it was but they always seem to get the ones with the smallest back plate so no room for connections behind the fitting and the ceiling bracket has to be perfectly level to get it onto it.
them fittings which hang from a hook, then the dome goes up, tightened by a little screw.... The drop from the dome is never straight.... Grrrr
Yep been there and wore the tshirt but just wait till you have to build a massive chandelier on your own then when putting last crystals on, and one of the fixed wires break which incidentally is unable to be bought separately yep as i said been there and still cursing about it .... ohh happy days
Reply to 2 hours to swap a light fittring in the Australia area at ElectriciansForums.net
Hi everyone. Hopefully someone can help with a little mystery i had today. The issue is fixed but I want to understand what was going on to help...
I have the typical LED on Dimmer switch. All the lights flicker in my house are very inconsistent times. By let me clarify by saying all the...
Hi all, Disclaimer: I'm not an electrician and have very basic knowledge of electrical installation. We've been putting in a new kitchen into an...
This is quite lengthy so get comfy... I had a bizarre call out relating to a job I attended about five years ago. The situation was they were...
Morning All I recently completed my first re wire and board change, (with help from the owner who is a gas fitter and plumper, who works with my...
