Even if the supply is 3-phase now, it sounds like the submain and two single-phase boards were put in at a time when the supply was split-phase. That would have made complete sense, there would have been no purpose running SWA with a 5th core when only two line conductors were present on the site, and the common neutral feeding two single-phase sub-DBs would not have looked at all out of place. Then, when the supply was upgraded to 3-phase, the two existing lines were put onto two of the three new phases, which work exactly the same as far as the neutral current and sub boards are concerned despite the difference in line-line voltage.
