Currently reading:
2 way gang lighting connection wirring issue.
Discuss 2 way gang lighting connection wirring issue. in the UK Electrical Forum area at ElectriciansForums.net
Tonykakz
How can i wire up this design so that i can have a two way lighting for the landing and also switch the bathroom.light on. Both cables are 3 core and earth.
Is this existing wiring or new wiring you are putting in. How is the line and neutral supply wired, looped at the switches or looped at the lights.
Wo
Will connect and let you know.
Worked up to a point bathroom light came on and off.One of the two Landing switches came on and off. By the way these two that worked ok were the two gang switch. The second switch for the two way switching for the landing turned on the bathroom light . So there must be some cross wiring. Any advice on how get it right.
Reply to 2 way gang lighting connection wirring issue. in the UK Electrical Forum area at ElectriciansForums.net
