Discuss 230v 3 pin commando polarity tester in the Industrial Electricians' Talk area at ElectriciansForums.net
hawkeyefxr
Is there a 230v 3 pin commando polarity tester that is a reasonable price? I have seen the Martindale one at £45.00
Ideally i would like one about £15.00 /£ 20.00.
I am just fixing a socket outside for my camper van to keep the topped up in the winter. The solar panels are ok for the summer.
I know i have connected it in the right polarity would just like to "see" it lol.
cheers
Commando plug, short flex, 13amp trailing socket, then 13amp polarity tester.
just what i would say. i have one in my kit.. cost about a tenner for the bits. but make sure yo get the polarity correct when yo make the lead up.
Just stick probe ends up it off your tester! I've done THOUSANDS like this in muddy fields
Related to this, for IEC sockets (10A & 16A) I just cannibalised some moulded leads, soldered on 4mm safety plugs and use it with my MFT to check both polarity and Zs, etc.
Our UPS measures 2kA PSSC due to the good voltage regulations, but we all know it aint going to deliver that if it came to a fault!
Reply to 230v 3 pin commando polarity tester in the Industrial Electricians' Talk area at ElectriciansForums.net
Hi all, Just looking at starting some testing since newly qualified, don't know if this is a stupid question or not. Is there an allowed...
Hi All New to this forum, have read the posts on here from google but only recently signed up. I'm having some issues and some input would be...
Hi all, Hoping someone can shed some light on this, i have purchased a surge protector and it will not fit the power cables i plan on using. I...
Greetings, everyone, After dedicating over a month to researching Solar PV systems, I'm nearly ready to make a decision. I owe my progress to...
I have a staircase about 25 feet long with two recessed lights (one up top, the other at the bottom). Each light is on its own 3-way switch, which...
