Discuss 2D led replacement for bulkhead with emergency option in the UK Electrical Forum area at ElectriciansForums.net
rolyberkin
Probably a silly question but is there a plug in option for 4 pin 2D emergency/maintained bulkhead using the existing control gear and batteries, if I plug in a 2d 4 pin LED bulb what will happen??:)
There are plenty of these about which can be retrofitted with no wiring alteration. Not sure about doing this in an emergency as it may affect its original performance, every liklihood it would improve it but who knows as the manufacturer probably do not approve different lamps.
https://www.NoLinkingToThis/p/lucec...Uv_toiP0ND7KdN9n41pBzbiCjjbnKkeRoCqSQQAvD_BwE
There are plenty of these about with can be retrofitted with no wiring alteration. Not sure about doing this in an emergency as it may affect its original performance, every liklihood it would improve it but who knows as the manufacturer probably do not approve different lamps.
I think I will pick one up on my way to the job tonight and see what happens! Have fitted them in 2D's before and they work fine, not sure what would happen with the emergency part but we will see later!:tearsofjoy:
Kosnic do a retrofit 2 pin and 4 pin with option of emergency module. Denmans do them. Also do a sensor version if needed with 10% luminance and lighting up full on trigger. You have to remove all the old gear/ballast/starter and wire direct into the 4 pin socket.
Reply to 2D led replacement for bulkhead with emergency option in the UK Electrical Forum area at ElectriciansForums.net
Hi all, a very long time I did a swanky grand designs type new build in the middle of nowhere, so in the middle of nowhere that it's a house with...
Hi I'm in need of some advice. First of all i'm not an electrician but do have an understanding of electrics as i come from an electronics...
I have two 4 inch recessed CLF 4 pin light cans installed in laundry room since 2012. The bulbs are fluctuating in brightness. I think the...
We bought a house with an array of broken (some cosmetic issues, some functional) downlights under cupboards in our kitchen. The bulb seem to be...
Hi I currently have 4 led bulbs in the bathroom and 3 of them arent working. The bulbs that are currently in are LOMAS LED GU10 220-240V 6000k 6w...
