Discuss 3/4 Outlets No longer working in same room in the UK Electrical Forum area at ElectriciansForums.net
Georgee
Last night, all of my outlets in my family room were working just fine. This morning, however, I discovered all the outlets that had something plugged in no longer work. I checked the breakers and all is fine. It’s just odd the one outlet that doesn’t have anything still works. We did have a couple storms roll through but that was all while I was watching TV and it was working. The TV is on a surge protector but the others were not. What could the problem be?
All the breakers are on and staying on, yes? Do any of the affected outlets contain a GFCI, and if so, do the test and reset buttons work? Are there any GFCI outlets nearby* that might have tripped, but not been noticed?
If nothing is tripped then it is quite likely that there is a failed connection at the first outlet along the circuit that doesn't work, or the last one that does. The fact that the outlet that is still operational didn't have anything plugged in at the time, may be just a coincidence.
*UK readers note that the OP is in the US, where GFCI receptacles have extra terminals on the load side of the GFCI that can be used to protect ordinary outlets downstream. Therefore one tripped GFCI point that may not itself have been in use, can disable multiple other points.
Reply to 3/4 Outlets No longer working in same room in the UK Electrical Forum area at ElectriciansForums.net
A friend's partner has an interesting fault, if it is a fault. She sets the shut down timer on the cooker and when the timer goes off (which in...
Our family room is part of an addition built a few years ago. We had an issue with nuisance tripping on an AFCI and the electrician came and...
A friend of the family recently lost her husband to the big C so I need to be careful. Every small thing is sending her into tears so when her...
Extremely low voltage on 120v line Hi, I’m not an electrician but my home has 20 amp breaker that has only one outdoor outlet on it with a GFCI...
