F
FRANK 1
Do i need a 3 phase switch fuse when the circuit is already protected by a MCB or is an isolator sufficient?
We need a lot more info than you have given here ...
The specifics and requirements of the load connected? (If it has a reduce cable size to load can it be classed as a fixed load)
Does the circuit comply with all cable calcs, volts drop and zs requirements?
As above are you changing conductor size?
What are you supplying with your three phase supply? sorry for asking but these questions have already been asked in one form or another we aren't mind readers Frank
