Discuss 3 Pole Switch Wiring Question in the Lighting Forum area at ElectriciansForums.net
Matthe1
Trying to replace this existing 3 pole switch with a smart 3 pole switch, am I identifying these wires correctly? It appears there’s an expectation for fives wires including two traveller wires so is it likely the two blue are both travellers in which case am I missing a ground wire?
Help would be appreciated.
Best wait for an American set of eyes, but at a guess from over the pond, the green will be ground, the two blues are both travellers, and the black is live (or switched live) There may not be a neutral there at all.
Is this a 2 way switch? As in one light controlled by two switches?
can you show the connections of your smart switch, or the wiring diagram supplied with it? You may have the type that doesn’t need a neutral to work
Yes, it’s one light controlled by two switches.
The smart switch does call for a neutral.
doubt that the smart switch will work unless you can get a neutral to it. there are smart switches available that don't require a neutral.
This works with this set up so the one most likely is the neutral wire, however I’m still concerned that something isn’t correct as there’s only one traveller wire connected.
Is it possible there’s only a need for a single traveller wire or is it more likely it’s missing a ground wire?
if you've got it working, it's most likely that you have it connected across hot and ground. that is verboten.
This is the concern. Ok, do what would be the correction needed for this? And why is it ‘working’?
Worth noting I did test the wires and only the bottom blue and black where ‘hot’ hence my assumption the top blue was the ground.
Highly unlikely the blue you have marked as ground is ground unless it has been repurposed (have you tagged them). Neutral is normally white or grey.
It is possible that is ground but it needs testing to be certain, same with the neutral. The most obvious colour for ground is the green but that may not be the case.
Reply to 3 Pole Switch Wiring Question in the Lighting Forum area at ElectriciansForums.net
Hi, I’m new to the forum. Thanks for letting me join. Asking for some diy advicd… I’m trying to add a couple more security lights to the existing...
Looking for counsel / guidance to replace an original Dayton On/off with speed control switch. I’ve checked with a couple local electrical supply...
FYI --- This is a U.S. installation. I'm replacing a three way switch (the UK might more sensibly call it a two way switch??) with a Kasa Smart...
This weekend I was replacing a hall light fixture in my old home (rewired circa 1980/90's) and noticed the work was done using one of the exposed...
