Discuss 3 position switch ; ON-OFF-ON in the UK Electrical Forum area at ElectriciansForums.net
MK do a 2-way and off switch module for their MK Logic Plus grid.
Cheers for that suggestion but I believe that's a retractive switch. I'm looking for a 3 position switch that does not reset to centre 'off' position.
Why do you need that arrangement?
I would just like the comfort of knowing that if the photocell went ---- up then I could still switch my lights on.
I thought installing an outside light to an existing circuit not in a special location was non-notifiable?
You are correct that it is not notifiable, but that is irrelevant.
Unless I'm much mistaken, as Wales still uses the 2010 version of Part P (which is much stricter than the 2013 edition used in England when it comes to what constitutes a special location/special installation), adding a light to or modifying a circuit that is outside, would require notification as outdoor lighting and power installations are considered special installations.
Reply to 3 position switch ; ON-OFF-ON in the UK Electrical Forum area at ElectriciansForums.net
I'd like to wire a six pin DPDT rocker toggle switch to turn a low voltage LED fixture on and off. The rocker toggle switch I have is an...
Hi all, I'm in the UK and have recently had a ducted extractor fan Mixflo 200W with timer fitted. The fan comes on with the pull cord and runs for...
I have a Firebird oil boiler that is controlled by a Honeywell timer (no thermostat) that has channels for hot water and central heating...
Hi all, I'm planning on adding some lighting to an old stone shed, there's currently a 2.5mm² SWA supply to the shed only supplying one IP rated...
