Discuss 3 position switch ; ON-OFF-ON in the UK Electrical Forum area at ElectriciansForums.net
Unless I'm much mistaken, as Wales still uses the 2010 version of Part P (which is much stricter than the 2013 edition used in England when it comes to what constitutes a special location/special installation), adding a light to or modifying a circuit that is outside, would require notification as outdoor lighting and power installations are considered special installations.
Yeah fair comment. The Welsh Approved Document P states that outdoor lighting and power installations are special locations, however it also states garages and sheds are not special locations.
Absolutely, but if you're putting a switch outside... I would say that constitutes work in a special location. It is a tricky subject that appears (like so much relating to the regulations) to be open to some level of interpretation.
I will concede that I have installed new lights outside, without notifying (these were not replacements and so the maintenance caveat did not apply), but that was early on and these days I tend to err on the side of caution.
The 2010 edition of Part P, one of the definitions of a 'Special Location' is outdoor lighting, also gives guidance in Additional notes page 8;
f) Detached garages & sheds are not special locations. Work within them is notifiable only if it involves new out door wiring.
g) Outdoor lighting....are special locations. Any new work in, for example, the garden or that involves crossing the garden is notifiable.
I do recall that a new luminaire attached & fed from main house, was not (i.e. front door light), but can't find reference to that.
Welsh Part 'P' : Installation of equipment attached to the outside wall i.e security lighting is not notifiable providing there are no exposed outdoor connections and the work does not involve the installation of a new circuit.
Cheers for that suggestion but I believe that's a retractive switch. I'm looking for a 3 position switch that does not reset to centre 'off' position.
As I already stated yesterday it is not retractive although such an option is also available.
Use a 2 gang 2way switch, switch A to act as a main switch feeding switch B common, one side of switch B feeds PIR, other side overrides PIR in parrallel and switches lights directly. You would be able to
1. Switch off everything and inhibit PIR from switching on in low light.
2. Switch on switch A and use switch B at any time to energise the outside lights even if the PIR fails
Could be a cheaper solution using simple components
@Markus, This entire thread makes no sense regarding your proposition for "ON OFF ON" switches (whatever they are).
You presumably have a supply cable with one line conductor, you can switch in one place only. (ie your shed, or if you chose to change where the switch is located, at the house).
You need another communication "channel" (ie a spare cable core, RF switch or PIR) to do both.
PIR will probably be disappointing, walking straight towards a beam from a long way won't work very well.
(You might ask your electrician if the underground cable is 3 core, and thus if it's possible to use the SWA as CPC, freeing up a core. - That possibility depends on several important design issues beyond the scope of this thread. Also, the work to organize that would in any case, soon become more costly than a cheap RF switch.)
Reply to 3 position switch ; ON-OFF-ON in the UK Electrical Forum area at ElectriciansForums.net
I'd like to wire a six pin DPDT rocker toggle switch to turn a low voltage LED fixture on and off. The rocker toggle switch I have is an...
Hi all, I'm in the UK and have recently had a ducted extractor fan Mixflo 200W with timer fitted. The fan comes on with the pull cord and runs for...
I have a Firebird oil boiler that is controlled by a Honeywell timer (no thermostat) that has channels for hot water and central heating...
Hi all, I'm planning on adding some lighting to an old stone shed, there's currently a 2.5mm² SWA supply to the shed only supplying one IP rated...
