sythai
Evening Chaps....
I'm after a 3 position switch so that I can switch a PIR between the following : perm ON / perm OFF / PIR mode
Not a pulse one though.
Any ideas, is there such a thing ?
Cheers Sy
Why dont you have a double switch?
1st switch is PIR on and off
When PIR is off the 2nd switch controls the Perm on and off.
If you need a wiring diagram Im sure I can do one quickly.
If you want a 3 way switch what about a 3 way rotary switch?
Was hoping to get something as 1 gang unit really...? Maybe something I can grid.
It's going in a domestic property and will be on show, so rotary not really poss.
Thanks anyway,
Sy
i used that switch recently, with Photocell lighting, perm on and perm off, ran the photo cell through a time clock. Works very well once set up and easy to install!
sythai,
infinity,
