Discuss 40A Isolator MetalClad or ABS in the UK Electrical Forum area at ElectriciansForums.net
Hi
I am wanting to purchase a Metal Clad or ABS 40A RCD/MCB isolator to feed a 40 Tube Sun bed, not quite sure whether to get just the 40A RCB or get a 63A RCB with a 40A MCB , something on the lines as per pics shown, I need it to be as small a foot print has possible.
cheers
Spike
Obviously an RCD doesn't provide overcurrent protection, so if this enclosure is to be fed by an overcurrent protective device, then just an RCD is all you need.
Otherwise, your enclosure will need to have either an RCBO, or an RCD and MCB of the correct type and rating.
So something like my first picture posted !
Need a 40A supply from the CU to feed the Bed, was just going to put a 40amp double pole RCBO just above the CU, then feed the 6mm2 cable direct into the Bed ! .
Spike
if you're feeding from a RCD why add another RCD?
Can anyone tell me if this is a correct statement, quote: Power requirements
Most people underestimate this, even some electricians if they haven’t installed a sunbed previously. As a
rough guide, a 200 Watt lamp uses about 1 Amp of electrical current, so a 40 tube 200 watt sunbed uses
around 40 Amps, which equates to 9.6 Kilowatts.
This means that the cable supplying power from your
fuseboard to your sunbed room needs to be 10mm (size in cross sectional area) which is thicker than most
shower or cooker cables. A 60 tube sunshower needs 16mm cable.
Its amazing how many people think that the sunbed can be simply plugged in to a conventional socket ! A 13 Amp plug has a maximum power capability of 3 Kilowatts before the fuse will blow.
What’s more, a sunbed is what’s called an inductive load. This means that when it starts up, it draws around
10 – 20% more current during the first few seconds, just like an electric motor.
Many electricians do not realise this, and although it does not affect the cable size required, it does affect the size of the circuit breaker (fuse) in your fusebox. If the 40 tube (40 Amp) sunbed in the example above was supplied via a 45 Amp circuit
breaker, it would trip out on start up, giving the impression that the sunbed was faulty.
There are two solutions: one is the obvious, to fit the next size up circuit breaker. Unfortunately, this is either
50 Amps, or 63 Amps. The wiring regulation do not recommend a 63 Amp breaker to protect a 10mm cable,
as it results in a mismatch that can be potentially a fire hazard, so a 16mm cable would be required, which is
much more expensive, and cumbersome to route through your shop due to its larger physical size.
The other option is to use a Type “C” circuit breaker in the fuseboard. Electricians call these ‘motor start
breakers’ and these allow a higher initial start-up current to flow without tripping, as used on industrial electric motors.
Problem solved! . :unquote.
Spike
have had a quick look, wow they do come in large power requirements.
at that power, a normal electrical supply in the uk could only power 2 of them with some spare capacity for heating and lighting etc.
I note they are available in 3 phase versions, this would dramatically reduce your cable sizes and perhaps be easier to install.
Reply to 40A Isolator MetalClad or ABS in the UK Electrical Forum area at ElectriciansForums.net
Hello all, Looking for help here as I've come across a strange call-out today. Bare with me here: Got a call from a customer saying they had...
I have received a panel built by someone else as part of a build I am carrying out. Unfortunately the customer has been involved in the selection...
4K
B
Prefix - I've tried to post this in automotive, but it would not let me. This may be because I have not been recently active. Apologies if this is...
E
I think I've Posted this before, but I've just updated it. Some of the sparks where I work still get a little confused of what the different areas...
77K
Ok, so I'm registered with Rated People. I don't use them very often but once or twice I have purchased a lead that has turned out to be very...
