Yeh , have a spare Henley Block ! .
Not really sure what that means but if there are no spare ways I would fit a suitable isolator through to service terminal blocks through to the existing board and your new supply.
Can anyone tell me if this is a correct statement, quote: Power requirements
Most people underestimate this, even some electricians if they haven’t installed a sunbed previously. As a
rough guide, a 200 Watt lamp uses about 1 Amp of electrical current, so a 40 tube 200 watt sunbed uses
around 40 Amps, which equates to 9.6 Kilowatts.
This means that the cable supplying power from your
fuseboard to your sunbed room needs to be 10mm (size in cross sectional area) which is thicker than most
shower or cooker cables. A 60 tube sunshower needs 16mm cable.
Its amazing how many people think that the sunbed can be simply plugged in to a conventional socket ! A 13 Amp plug has a maximum power capability of 3 Kilowatts before the fuse will blow.
What’s more, a sunbed is what’s called an inductive load. This means that when it starts up, it draws around
10 – 20% more current during the first few seconds, just like an electric motor.
Many electricians do not realise this, and although it does not affect the cable size required, it does affect the size of the circuit breaker (fuse) in your fusebox. If the 40 tube (40 Amp) sunbed in the example above was supplied via a 45 Amp circuit
breaker, it would trip out on start up, giving the impression that the sunbed was faulty.
There are two solutions: one is the obvious, to fit the next size up circuit breaker. Unfortunately, this is either
50 Amps, or 63 Amps. The wiring regulation do not recommend a 63 Amp breaker to protect a 10mm cable,
as it results in a mismatch that can be potentially a fire hazard, so a 16mm cable would be required, which is
much more expensive, and cumbersome to route through your shop due to its larger physical size.
The other option is to use a Type “C” circuit breaker in the fuseboard. Electricians call these ‘motor start
breakers’ and these allow a higher initial start-up current to flow without tripping, as used on industrial electric motors.
Problem solved! . :unquote.
Spike
have had a quick look, wow they do come in large power requirements.
at that power, a normal electrical supply in the uk could only power 2 of them with some spare capacity for heating and lighting etc.
I note they are available in 3 phase versions, this would dramatically reduce your cable sizes and perhaps be easier to install.
And this statement:
Sunbed/Vertical Tanning Unit Electrical Specification Fuseboard: Lie down sunbed: Single phase: Three phase: 80 Amp MCB 3 x 35 Amp MCB Vertical Tanning Unit: Single phase: Three phase: 100 Amp MCB 3 x 35 Amp MCB Residual Current Device (RCD/RCB/RCBO) is optional, but if fitted must be 100mA trip, not 30mA. Cable Single phase: 18mm Twin and Earth (Lie down and vertical sunbeds) Cable 3 Phase: 3 x 4mm (Lie down sunbeds) 3 x 6mm (Vertical sunbeds)
The part were it says use a 100mA trip as apposed to a 30mA !!
Not uncommon for high power things. It is not to protect you here, it is usually for fire provention or in cases where it is a TT supply (earth rod, not a low resistance cable back to the supply).
That would be C-curve trip characteristic in those cases, usually means a high switch-on surge.
  • B-curve = 3-5 * In (rating current) for the "instant" magnetic trip
  • C-curve = 5-10 * In
  • D-curve = 10-20 * In
Yes , but why would a Sunbed need a C -curv as opposed to a B- curv and a 100mA trip as apposed to a 30 mA trip !
The C-curve is probably due to the inrush current of the inductive starters for the UV tubes. The 100mA probably from having several of them each with some noise filtering.
If it is hard-wired and no issues with the cables being buried < 50mm then you don't need the RCD aspect. So if run in cable is definitely >= 50mm, or in trunking, or using SWA or (at lower currents) Flexishield for protection against penetration damage causing a shock risk, then you can just use the MCB.
Getting 3-phase RCBOs can be difficult, sometimes easier to have a MCB at the board and a separate RCCB for the RCD action.
