Doing an EIC and just making sure that I understand this correctly.
I have a domestic installation where I have run 2 x swa cables out to pumps. Pump 1 is purely for an emergency pump in the event that the area behind a protective bank should start to flood (where there is a septic tank). Pump 2 is specified by the septic tank installation designers to clear the 'processed' water well away from the water course.
My original intention was to terminate each swa into rotary isolators which were going to be on a tank installation manufacturer supplied elevated ip rated platform. However, when this platform arrived it came with two moulded c form socket outlets and no space for my isolators. It looks a bit like a bird table with a plastic lid. I have therefore had to connect to two socket outlets bringing me under the scope of 411.3.3.
If I label these two non-rcd protected ways on the cu with the black on yellow tape, I believe this would have me covered under exception (i) (b).
About right or is there a bit more to it?
