Hi,
I have an aftermarket ignition coil harness utilizing a 5 pin relay, the relay is corroded and doesn't work. It's also discontinued by Denso and they don't have a wiring diagram for it (P/N 056700-7240).
I managed to source a similar harness from a later model which has a slightly different ignition setup and uses a different 5 pin Denso relay (P/N 056700-6780).
I'm trying to figure out if i can safely use the latter relay on my current harness, so my questions are:
1. do all 5 pin relays share the same pin-out and mechanism and simply have different ratings?
2. Does anyone have a diagram for the 056700-7240 relay? (i already have the 056700-6780 diagram).
Any help would be much appreciated!
