Discuss >50v on megger when doing ELI test in the UK Electrical Forum area at ElectriciansForums.net
I've got a megger mft 1552 and if the above 50v touch voltage appears meaning the voltage to earth is above 50 it will abort the test as it has an inbuilt safety setting whether it be efli or rcd testing
No RCD on the circuit no was a basic socket replacement and went to do a ELI and found this issue so thought i would investigate further and IR tested the circuit and found the N-E fault,it just seemed weird when i tested with the faulty cable isolated the fault cleared. Like you say it may be my meggar it just threw me as never had this issue before.
Have you cleared the fault and retested. I am confused with this because a fault on one side of a ring final should also occur on the other.
Reply to >50v on megger when doing ELI test in the UK Electrical Forum area at ElectriciansForums.net
I've just been to a job to replace a burned out switch where the customer supplied his own Arlec dimmer switch. During a dull moment, I read the...
Hi All New to this forum, have read the posts on here from google but only recently signed up. I'm having some issues and some input would be...
In my line of work it's very rare that I ever have to change a DB. I'm largely in maintenance; occasionally have to add new circuits etc. so in...
Hi there, I’m a new member to the forum and felt like I could do with some additional insight into a fault I came across on a call-out at the...
Hi guys & gals, I gave in and bought the new Megger MFT-X1. Got my hands on it Friday night, had a little play with it, used it at work on Monday...
