Discuss 6mm (T&E) Single core or 6mm multi strand(T&E) in the DIY Electrical Advice area at ElectriciansForums.net
seanevans00
Can somebody kindly explain the difference the above. I currently have 6mm T&E multi strand running from my main consumer unit of a 32amp mcb which then ties up to a junction box where I run SWA to my shed. I
Reply to 6mm (T&E) Single core or 6mm multi strand(T&E) in the DIY Electrical Advice area at ElectriciansForums.net
I have had my kitchen rewired and plastered. I have had a 6mm t+e on a dedicated 32a circuit for a 60cm electric cooker. In hindsight, had i known...
Good Evening. I’m currently carrying out an EICR. I have a cooker circuit radial with a 32amp mcb fed from and RCD split board. There is a 45amp...
Hello hope you can help I have a single oven 2.4kw max and a ceramic hob 6kw max I would like to put then both on the same circuit so i was...
Hello all, I wonder if I can get some opinion on my deliberations on an old TPN installation with numerous 1P sub-boards wired up with 16mm T&E...
