Discuss AC Circuit Theory Maximum Power Transfer in the UK Electrical Forum area at ElectriciansForums.net
Fantastic!
Chr!s, thank you. I've been looking at how to get power as watts which will never work without the correct values. Never though of it as a percentage, which by definition is a value.
I've just sent you up to 100 thanks as well. Appreciate your time.
Fantastic!
Your welcome. Good luck!
Thanks for the replies! I'm looking to get the maximum power transfer for the load impedance. View attachment 17445 To calculate the power surely requires either current or voltage to which I am only given the 50Hz supply and the calculated impedance. I've attached a drawing (yeah I know!) Chr!s, 'There are two methods, the trial and error to plot from 0 - 3 ohms, or the first derivative method' I've not heard of the trial and error plot, is there any chance (please!) you could elaborate on this. Using either of these applications you can find the maximum power from only Frequency & Impedance? Thanks
did this on microsoft paint from scratch, please excuse as was done at 2:30 Am as I was up :rolleyes2:
grant,
There's an error in your solution.
The inductor is reactive so you can't just add it to the resistances.
X[SUB]L[/SUB] = j219.9
so Z[SUB]Th[/SUB] = 330.3 + j219.9
and Z=sqrt(R[SUP]2[/SUP] + X[SUP]2[/SUP])
Blame it on it being 2:30am! :)
Good drawing btw.
Reply to AC Circuit Theory Maximum Power Transfer in the UK Electrical Forum area at ElectriciansForums.net
A coil is connected to a 100v a.c with 20ms, and supply current taken by the coil is 6a calculate the frequency (50Hz) the overall impedence (16.6...
Hi All, I am currently learning about AC and DC supplied coil and have been given the scenario below. I understand the first few steps but then...
Hi, Hope someone could help with below situation or recommend a good forum to ask about or find information on as I read a lot on the forums and...
4K
Hello, Sorry if this isn't the right forum for this. Didn't look to be far off... So I'm looking for some advice please with regards to...
I intend to build an electric kiln for pottery, clay ( and other materials ) sculptures. The internal dimensions would be 40cm(height) x...
5K
