I
irishsailor
Morning All
My mate wants me to add an RCBO to an existing CU.
Does it need its own neutral / earth rail or can it go on the rails with the rest of the neutrals / earth
Chris
Hi , Put the nutral from the circuit into the rcbo - the nutral from the rcbo to the nutral bar ( from where you took the nutral of the circuit ) take the earth lead from the rcbo to the earth bar ,connect in with the earth from the circuit .Just make sure you have room for the rcbo .
Chris, as you`re putting the RCBO on the unprotected side of a split board? you`ll need to make your neutral connection on the unprotected neutral bar.
The functional earth (the cream one) can go anywhere on the earthing bar, altho i tend to place them next to the Earth Conductor/ Main Bonding terms, away from the cpcs to maintain cct numbering
