Discuss Adding LED Lights for Wardrobe in the Lighting Forum area at ElectriciansForums.net
TheTwist
I am wanting to add some LED lights into my wardrobe shelving. I have seen a few around but I am not sure if they will work to my needs.
Basically, each shelf is quite dark and it’s hard to see things clearly, so I want to add lighting to each of them.
What I am looking for is when I open the door, lights will switch on and when it closes it will turn off.
I want them to turn on and off either day or night so basically based when the door is opened.
Anyone recommend anything that they have used? I would rather not wire it to the mains electricity.
I've got one of these in my wardrobe and it works a treat. It has a built-in daylight and motion sensor, it's bright enough to light up my entire wardrobe and it uses 3x AAA batteries which last for about a year. I'm sure you'll find something similar on Amazon or EBay.
Ikea do a couple:
You'll need a driver and a nearby 13amp socket for the second option - there are drivers at the bottom of the page linked to above.
Reply to Adding LED Lights for Wardrobe in the Lighting Forum area at ElectriciansForums.net
Hi all, Great forum with lots of advice read and greatly received over the years! I have a question here that I am hopeful somebody here can...
The mrs has just decided she now wants a TV wall with built in shelves etc We are going to build it out of mdf and then paint, I am just...
hello all. I am trying to add led strip lights to my boat trailer. I have marine grade submersible lights. I will have them running parallel to...
I want to buy two of the above for my property. I am on a budget. The property can get battered by driving rain, finding an outdoor LED flood...
Hi, Some advice would be appreciated… I have 4 downlights in the bathroom and want to add a motion sensor to turn on just one if everything is...
