Discuss Advice needed on a Power Adapter in the Industrial Electricians' Talk area at ElectriciansForums.net
N
nuttycomputer
Hi..
I have a Freeview Box with a external Power Adapter which I plug into the back
Its 5v 1200mA
Its failing as it runs for about 15mins then switches off the Freeview Box, even used a voltmeter on it and it drops from 5v to about 3 ( so it is the Power Adapter and not the Freeview box)
I've used a smaller Power Adapter which is can be set for 3 - 8.4v and this seems to run fine with the Freevew box, now it does state on the this adapter that at 5v its mentions on the label 2.5A and at 6v 2.2A
It seems to run the Freeview box fine, I just need to know will it put a strain on the smaller adapter and be a problem or would it cope ok ?
The old adapter looks bigger in size compared to this smaller one..
This new adapter is intended to run quite a good range of electrical devices (Digital Cameras, Keyboards,..etc.etc)
I have enclosed a photo of the OLD Failed adapter ( BLACK 5v 1200mA)
and a photo of my spare Multi Adapter ( SILVER )
Any views would be helpful please...
NEW (SILVER) and OLD ADAPTER (BLACK)
NEW ADAPTER SPECS:
OLD ADAPTER (BLACK) SPECS:
Multi adaptor should be fine mate, check if it gets abnormally warm after being used for a while, but should be ok
After 3hrs it was only slightly warm,, nothing abnormal there,, nothing hot, will continue to monitor..
Works Great !!
Thanks for the advice Spudmiester :)
Regards
NC...
Reply to Advice needed on a Power Adapter in the Industrial Electricians' Talk area at ElectriciansForums.net
Hi All, We have an old Country villa in Spain. The housing electrics were not good so the house recently has been completely re-wired to a good...
Thank you in advance for your help. I recently purchased a home and while removing some built-ins I found that they had a 14/2 wire running...
