Hi
We had the light (photo attached) installed a couple of years ago - it still works but the bulb is faded but needs replacing.
Is it quite easy to replace myself (someone with no experience)? Or do I need to get someone in to do it?
Thank you!
James
It looks like an all in one LED fitting, the lamps are not changeable.
new light fitting is required.
It looks like water has got inside the glass but its not definitive from the photo.
Thanks James. Can I replace the whole thing myself or would you recommend getting someone to do it?
Can that light be overridden by a separate switch as it looks like a four core cable going to it?
