I don't recognise it, perhaps there is a maker's name on the cover? I think there is an important part missing: See the diagonal slots in the bakelite near the terminal screws? IMO there should be a ceramic or Sindanyo tube across the middle that slots in there, through which the fuse wire is supposed to be threaded before tightening under the screws. That wouldn't do a particularly good job of containing the arc on modern fault current levels, but at least it would stop it splashing all over the base and tracking across the contact blocks and mounting screws. Without the tube I would consider this quite hazardous if it blows and in need of replacement. Can't tell the rating, might only be 30A although that looks like 60A wire.
