N
Notanelectricia
Hi. My husband took out a non working spotlight bulb from our bathroom two weeks ago and we haven't gotten round to replacing it yet so there's been a missing bulb.
The RCD tripped this morning for this circuit so I've kept the fuse off for now. I assume steam has caused the problem and will buy a replacement bulb today.
Is it as simple as this ie it is bound to dry out of its own accord or do I need an electrician out? I have no money till payday next Friday. Can it wait till then?
Thanks.
should be OK as long as there is not an underlying fault. replace the bulb (with the breaker off), then reset the breaker. if there is a problem then either the breaker or the RCD will trip. if so, then you need an electrician. several forum members in your general area. one will surely come to your aid if needed.
don't buy the cheap crap from supermarkets. go for branded, e.g. osram. better still, save some cash and replace the halogen bulbs with SMD LEDs, about £8 apiece but you'll save that in a few months in lower running and replacement costs.
Ok. Well, I found a bulb in the shed and went to replace it but found the bit where you attach the bulb to has actually come away and is hanging rather than tightly fitted and my husband simply tucked it in to the spotlight to stop it hanging down but failed to mention this and is now at work for the day.
It clearly is a job for an electrician. My husband isn't back till late afternoon and I can't get cash till he is home. Will this matter? Do electricians need money at this actual visit or can it wait till later in the day? Will I even get anyone out today?
Thanks!
ps any recommendations for electrician in South Croydon??
the bulb holders are usually free floating in these fittings. once the bulb is in, it's held in place with the bezel or a circlip. my suggestion is to heave the bathroom lights switched off and reset the breaker, see if the RCD holds. if you've been without bathroom lights for 2 weeks, sure you can manage for a few days more. don't think you'll get any offers from here till this evening when guys come in from work.
That is probably normal, the part you plug the lamp into is normally a cap on a wire that does hang out of the fitting, you should be able to connect the lamp to this then push it back into the light, then there should also be a ring that fits in after the lamp to hold it in place
Thanks. The one light has worked ok up till now. I can live without the bulbs but I am paranoid about a fire starting especially as I have kids in the house. I assume though that if I keep the fuse switched off nothing will happen? At least it doesn't sound a big job and that it can wait until we can get someone out.
Thanks very much for your help.
- - - Updated - - -
Ok. I will try to put the bulb in.
If it's a mains halogen slot the lamp into the holder and twist clockwise untill it locks.....there are two keyhole shaped slots in the lampholder. If it's LV there are just two needle like pins on the lamp which just marry up with the holes in the holder and push in.
Oh dear. The wire that is on top of the light fitting is in in half and looks like its been gnawed although cant see how this is possible as its the loft above it.
Im over in addiscombe so not far.
I have a job on today but should be able to take a look for you later in the afternoon if you like?
sounds like rodent damage...in which case leave it off on the circuit breaker/fuse and see about getting an electrician in.
any chance of a photo of that?
edit: there you go. post #11. londonfire can pop over.
Squirells or rats possibly i have had a few in croydon. Had a cooker cable a rat had done amazing what they can do with those big insulated teeth!
Seen the fire resulting from squirels in a loft which could have been avoided if the kitchen fitters had brought everything onto the recently fitted rcd board for there install. Will take some picks if it is.
Hi. That sounds great, london fire. How do I get in touch with you? I think I have attached picture.
