Discuss Advice please on a 220v receptacle in the DIY Electrical Advice area at ElectriciansForums.net
cwoods
Hello and thank you for accepting my request to join the forum!
So, I have had a Miller 140 welder now for 5 years or better and it has suited me fairly...until now. I purchased a mini jet boat project and I need a welder that will handle aluminum welding better, a 220v unit is needed now.
What if any options do I have for adding a 220 outlet in my garage??? I have a subpanel with the breaker positions full. I have read recently of tandem breakers, is this a possibility to use just to free up a dual position for a 50 amp breaker?
I would like to add a 50amp dual for a 220v outlet straight down short run under the panel between the studs in the wall using appropriate gauge wire. I have included pics in hopes that I may get some feedback on this issue and I thank you for any feedback in advance!
Reply to Advice please on a 220v receptacle in the DIY Electrical Advice area at ElectriciansForums.net
I’m running wires to the basement for future basement finishing. I’d like to add two circuits of outlets (one on the finished side and one on the...
Hi, New to the forum. I have two very specific questions, for the setup below. Setup details: Currently I have a setup with an outlet used for...
Hello, I live in Mexico, where I have a small, un-official trailer park on my property. The property is serviced by my privately owned, 650amp...
Looking for some advice and insight on best practices here. I have an attached garage 25 feet away from my main 200amp service panel in my home...
Ok I’m not electrician, just trying to save money. And just wanna get some input before I continue. I added a 20a breaker to my circuit box, ran...
