H
harrymonkfish
Hi All,
I will be installing my first earth rod tomorrow and would be gratful of any advice.
I have bought one of these Earth Rod Terminal Cover appears to need fixing to the wall? does is kind of hover around the rod, I can't see what else I can do with it? If it is fixed to the wall, then the rod would also need to be as close. if the footings are wider than the wall then its not going in.
Any comments please
Harry
They are a bit floppy but are fine for domestic situations where interference is unlikely. I usually knock the rod down far enough so that the box just sits on the ground, and then run a plastic conduit from the box to the wall with a bend to enable it to be secured with a couple of saddles . I'ts a bit of a fiddle cos there's no space in the box but the end result is reasonable mechanical protection.
Yeah, agree with wirepuller, they're good enough to protect the termination but they are fairly crappy unless wedged against the surface or joined into 20mm conduit.
The sunk earth rod boxes are much better as they present a flat plastic mini-drain cover on the surface and the rod termination is down within.
harry, never seen one of these, we usually get an earth pit box mainly pot or plastic, they give by the looks of things far more room than that thing u r going to use.
Or does that terminal box fit inside the earth pit mate, please enlighten me please.
Don't think you'd need to use an earth pit box AND a rod cover. The sunk boxes are great for new installations but I generally hit a finance problem with upgrades where people don't want to pay for a sunk box....therefore I generally upgrade the cable and add a cap to protect the termination.
