T
Tidy Max
Been talking to a gentleman about a rewire for a few months now and now that he has the keys to the house he has realised how much work is to be undertaken.
Instead of me doing the rewire in one go, he has asked if i can advice him on the rewire so he can do as much of the laboring as possible.
Now obviously some work is better than no work, but im abit unsure as to what to do as i haven't come across this before!
Realistically if i am having to go back at the end of every week to make sure every cable route or bit of work has been done properly the cost wont be that far off that of a full rewire!
I am going round to the house with the geezer tomorrow to check it out and see what we can do.
Thanks in advance for any replies.
Max
best get him to work with you while you are there. helping pull cables etc. then you are on top of what he does. you can mark out chases and leave him to get on with them as that doesn't involve any installation as such.
If you can get him to do the donkey work like lifting carpets, floorboards and shifting furniture then can't see a problem. Could get him to help you pull cables etc to save time (time = money), but wouldn't be happy letting him do any install work himself.
Like someone said above you could let him chase the walls if you mark out the chases.
Having him work with you is a bit of a minefield unfortunately. You are taking on responsibility for his health and safety, which means you need to carry insurance for him as well as you, and you will be obliged to supply him with PPE and training for any equipment (wall chaser, ladders, drills etc) which he uses whilst working with you. Any damage he may do to next door, the services etc will also be dropped in your lap.
If you give him a verbal list, or dictate to him and let him write down, what he should do and where so that he carries on working on his own house then you need none of the above.
First fix it.
Let him relay the floors, plaster the chases, do the painting.
You second fix it.
Job done.
Laurie
Cheers for the advice, top notch as always! Going round to the house tomorrow so i will assess it and see how it goes.
I appreciate him working for me could be a mine field, i will probably just detail all of the lifting and shifting needs to be done by him.
Which is a shame because i'm 25 and hes 60+!!!
Thanks again
so am i, but us owd 'uns can still give you young wippersnappers a run for your money,
Lol yeah i worked with a 60+ guy before and he was strong as an ox mate used to be a gymnast in his early days he could lift things i couldnt lol and i always felt i had to work harder than him due to being younger lol
fair point! i just feel like if there is anyone doing the grunt work (regardless of time and money spent on quals) then it should be the younger one! But your right, thy are stone walls too il say i want 75mm chases just to be on the safe side lol.
I had this once before mate, was asked to quote fot a rewire bu the guy wanted to run all the cables do all the chasing and for me to do the final connections. He basically wanted me on site to tell him what to do. I declined.
Anyway same guy calls 3 months later and says he needs a DB fitting.. It wasnt too far out the way so i offered to pop along.. waled in the living room and there were wall lights spured from sockets and most of the cable chases were as the crow files...
Instead of 6mm feed for the induction hob he had 2.5mm x 2 feeding the cooker isolator and then to the cooker connection point..
Then the best bit was the 2way lighting. Instead of 3 core he had every switch back to the pendant. So one light 4 swicthed had (6 cables - Loop in Loop out, and what should be the 2 way and intimidiate again back to the pendant.
After declining he got someone else.. And guess waht another phone call.. Can I help him as the lights wont turn off..
AGAIN.. I Declined.....
If the client want to save money get them to do the room clearing, loft clearing, carpet lifting, chasing, back box holes and making good.
I've done that in the past and it works OK.
PS. If they want to supply the parts, make sure YOU will charge for the time you will waste, which you will, when the wrong parts are supplied.
I wouldn't even let him do the chopping out because it won't be to the standard that you want it. You'll have back boxes protruding and not level. Unless they have severe construction experience then fair enough!
And most importantly make the TEA!!!
