Discuss AHU Faults in the UK Electrical Forum area at ElectriciansForums.net
S
spatz
I'm having a problem on an AHU that will not hit btemperature the actuators to htg coil are fully open and hot water is passing through but i am not getting my set point met by 8 degrees C, can anyone give me some advice please
More info needed.
Is it Full fresh air, fresh air+recirc or recirc only?
Are the filters clean?
Is the coil clean?
Is there a difference in flow and return temps on the pipes?
Has it ever worked correctly?
Has it ever worked correctly given the current outside temps?
Has anything changed in the area it supplies since it last worked correctly?
Is the boiler flow temp at it's setpoint?
Is it a dedicated boiler to that unit?
Hi mate
I have alot of this day to day, what's your flow and return on Hester battery? What's the off air temp? Finally have you checked the actual off air temp with a meter?
Reply to AHU Faults in the UK Electrical Forum area at ElectriciansForums.net
Hello ! I am building for some time a cct to drive a 3digit multiplexed LCD. (from aliexpress) From the sellers on aliexpress I managed to find...
I hope this is the right place to post this, please redirect me if not. I've spent quite some time reading the forums, so I apologize if I've...
Hi all, Im new to the forum and wanted to check something and maybe get some advice confirmation. Ive got halogen wall lights which use a...
