chrisdhorton
I have been given a old air compressor, I believe it's a Stanley as it's yellow but not sure as all the markings have worn off.
It has a 16amp plug fitted. I bought a 16amp to 13amp adaptor so I can plug it in my garage socket. When I plug it in and turn it on the motor spins once then cuts out. The 13amp fuse in the plug blows every time.
My garage circuit is on a 32amps breaker. So I didn't think Its because it can't draw enough power. It has two capacitors (start & run). I thought they were the problem so I swapped them both for brand new ones, but that didn't fix it.
I've depressurised the tank and checked the none return valve. It looks fine. I've tried running it without any lines attached to the pump to see if the motor will at least run. Same thing happens.
All the electrical connections look ok and there are no breaks in the cables.
I'm not sure if the motor is just to worm out to run. The motor spins freely but it's rusty. I can't test how much power it is drawing as it just blows a fuse strait away.
Not sure what else to try?
