Discuss Alternator only putting out 12.3 v after Tachgraph fitted ? in the Auto Electrician Forum area at ElectriciansForums.net
As the Title, After the tachgraph was fitted it throw up a power interuption warning on the tacho and has done a few times since , The alternator is only showing 12.3 v when testing on the running vehicle , Lights dipping when clutch pressed on dash and exterior headlights etc for a second or 2.
Alternator just removed and tested and is putting out 14v and is absolutely fine. What could be causing this from just having a tachograph fitted. Vehicle is a isuzu Dmax , Any help or advice much appreciated.
Hi,bit late to reply,but will have a go...
Is the charge warning light/function working?
Has the vehicle charging system been tested in real time,with a suitable analyser,as it may well be some development of smart-charge technology.
The tacho will maybe have a running live,as well as a permanent live,and if this is taken from the wrong part of the alternator circuit,it will upset the PWM signal,which controls charge output.
Reply to Alternator only putting out 12.3 v after Tachgraph fitted ? in the Auto Electrician Forum area at ElectriciansForums.net
Vhicle: Fiat Grande Punto 1.2 Petrol. 24/9/2021 The original battery died and was replaced: I'll put that down to old age. It was replaced...
The symptoms its been having to start with was the fuel gage only working sometimes and when i play music from my phone when a loud song came on...
Having a bit of a nightmare with what should have been a simple job. Back in January I replaced some old Varilight dimmers which had failed after...
P
Hi I'm new to this forum and there looks to be plenty of knowledge on her so here goes! Basically I am an experienced independent vehicle repairer...
7K
I thought my old alternator was toast (after all, it was 15 years old), but a brand new one is doing exactly the same thing: the belt is snug (and...
5K
