C
Chris Llewellyn
Hi everyone, I've got my am2 coming up soon (2nd attempt sadly) And thought if anyone had any helpful advice. I failed on the schedule of inspection form and the fault finding section. Does anyone have any tips or advice to share then please do :) .
cheers
I had 4 on the s plan heating system 2 on electric shocks whilst touching a boiler and water tap and the last one was on the ring that it didn't comply with the regs which I found that there was a cross connection between L-N.i can't remember the actual faults that came up on the heating system though sorry but if you could help with regards to the others then that would be brill.
There's no real advice to give. The AM2 is a test of your ability as an electrician. If you have worked hard over your apprenticeship and are ready to go out into the world with your electricians card, then passing this practical exam proves it.
Read back through your notes on types of fault (short circuit/ open circuit/ high resistance etc) and the techniques used to find them (half split etc..).
Good luck
