Discuss AM2 exam in the Electrician Courses : Electrical Quals area at ElectriciansForums.net
J
joe1993
hi all
Ive got my am2 exam 5th december and was wondeding if anyone could offer any notes or a outlook on the exam do you get wiring diagrams for everythink you do or only the heating system? Also do you get told what size breakers to use?
Joe
You get a heating system diagram, everything else you need to know how to wire up.
If you look in the spec it should specify what breakers you need to use.
I advise that you take the PRE AM2 as it gives you a great insight as to what's in the exam and how the days will be.
Okay thanks what about the lighting because i no were going to be using twin and earth but how do you know wether they want it 2 plated or 3 plated? Also how in depth is the testing for example the tick of sheet does this need to be 100%? And for the supply charatistics is this done for you or do you haveto go look?
For the lighting, 2 plate, as shown in the diagram.
Testing is very in depth, you get marks for each box on the test sheet. For example, if you tick 3 phase supply you get a mark.
If you cross bonding to oil tank you get a mark as there is no oil tank. No one knows the pass mark.
You have to "find" the supply characteristics, trust me when I say you won't have to look hard for them.
Hope this helps
Hope this helps
Thats great thankyou for your help dont spose you have any filled out tick off sheets the way they would look in the AM2? also any other information you have that would help me would be great.
Thanks again
Thankyou i have booked the 1 day pre am2 so hopefully this will help alot i do know how to do the things there asking for but its just making sure its done in the way that they want it. Do you know much about the motor circuit is it true we need to set the thermal overload on it as 1 of my friends said you dont haveto but ive read on here people saying you do?
I took mine back in February (adult route) found the overall exam quite easy to be honest, I'm not saying you don't need to look through your notes/books from college/night school days but the pre test was a absolute god send and in a roundabout way they more or less tell you without actually telling you what the exam will entail.
Not going to lie the fault finding is hard 7 faults on a copy of the installation you will have carried out and you MUST obtain 5 of the 7, a few of the lads on my exam day 3 of the 6 really couldn't get there head around the testing and didn't even complete it, but remember any section you pass you don't have to take again if you have issues with other sections of the exam.
All I will say is isolation procedure can be the making or breaking of this exam so make sure you have that nailed to a tee.
Good luck
Madness I took mine nearly 19 years ago and I was worrying like you over thinking things. When you get in there it will just happen naturally. At least you haven't got to put up all the containment like we did! But good luck.
Yes we used to have to pop rivert the galv trunking bends........
Never done it since all manufactured bends
Reply to AM2 exam in the Electrician Courses : Electrical Quals area at ElectriciansForums.net
Hi everyone, I'm currently working towards getting qualified as an electrician and am hoping to get my foot in the door with an apprenticeship or...
Hi all, first post so go easy! This is for people who are looking for more info on the course and exams and is from my experience of doing the...
Evening everyone . Currently looking at pricing a job up . It’s a hot tub supply . Outside socket with a few spare ways in an outdoor cu . 10mm...
