polo1
As above, can anyone recommend a make/model of metal housing to accommodate only an rcd? I'm guessing too, that these will require a metal cover if used in a domestic setting?
Yeah, that's what I want to avoid! I do a fair bit of work in rentals, where lots of showers have no rcd protection, hence the enquiry.
Well true, but if this enclosure did not need to meet the same standards or satisfy the same regulation as CUs, he could just use a plastic one.
I was assuming this fell under the "similar switchgear" part of the regulation hence the question.
and if he's adding to an existing install then fit an insulated one!
Yeah, I was posing the question for two reasons. My understanding is that, in the situation I described above ( fitting an rcd to an existing circuit), then the rcd enclosure had to be metal, with cover. On this basis, also wanted recommendations for a suitable unit.
i can't see how a plastic/ insulated one complies ( unless others can point to other info).
polo1
Glasgow
Business Name
GW Electrical & Security
Amd 3 compliant, metal, two module unit
polo1,
Midwest,
