Discuss Amount of LED downlights in a lounge in the UK Electrical Forum area at ElectriciansForums.net
TJC1
Does any know have a usual spacing for LED downlights? Im normally like to put a good amount (maybe a few to many) But i always work on id rather put to many in with a dimmer than not enough!
Starting a new build tomorrow and customers don't want loads of downlights. The lounge in 7 x 3. They only want to put in 8 JCC V5os. Does any one have a design method or average amount per square meter?
I tend to go with 600mm from a wall, then 1200mm between fittings. 700mm from wall in kitchens to avoid the wall units casting shadows.
The height of the ceiling can be a factor and the beam angle of the fittings. Kitchens and bathrooms would require more light than a lounge really. Whatever suits the room really.
Maybe the customers are planning on having table lamps around the lounge?
8 sounds right for that size of room.
My living room is about that size, but its extended from an existing room... so ive got 2 pendants. The original and a new one.
Hardly ever used. I wish I'd put downlights in now.
The kids like to play Just Dance on the Wii, and inevitably punch hell out of the lampshade.
In my lounge i have 10 in a H shape . 4 on each side wall and 2 in the middle on 2g dimmer . Usually only have 2 on in the middle and dimmed . Lounge is a relaxed environment in my opinion so should be dim and cosy
EEeeeh! ...turn t' lot off...n' jus stick t' pair on,luv...it's reet cosy!...
....typical Yorhshireman...romantic,at 8 watts ;)
Not sure what the fittings are (lms) but say 500each works out roughly at 190lm/sqm (assuming equally spaced). This would be reduced at floor level so probably towards low levels for a lounge (Think recommended is around 300 for a lounge)
Dark decoration/furniture will reduce the impact of the lighting even further.
One of our suppliers offers a lighting design service if we need a more accurate design which is really helpful so might be worth asking around at wholesalers.
In the past, I have contacted the supplier of any lighting fittings I intended to use, for lighting a particular area, and required lighting levels to supply a lighting design, the ones I used were always willing to help. I maybe worth your while to approach your supplier through the wholesaler if they could supply this service, 99 to 100% of the time they agreed, only saying this approach may help.
Most of the larger electrical wholesalers offer a free lighting design for account holders.
Yes don’t grab the first lights you see at the wholesaler because they are at the right price point. Get the photometric data and use Relux or Dialux and do a calc. Or get the lighting supplier to do if for you more st will do it for free. 1200 spacing for LED lights will most likely produce too much light dependent on fitting and task in hand. Do a calc and get it right, after all you would not make a guess on electrical loads please give it a thought, and at the end have a environment that works and a happy client.
All this lighting design from wholesalers and lighting design software and calcs seems a bit excessive for a simple project like lounge lighting
It is only optional most do it from experience using the same type of fittings on previous jobs.
Hands pointing in the air approx 1200mm space , base it on old 50w output (340 Lumens) singing "We will, we will rock you" stick low tack tape on ceiling so customer can see layout, then re-re-arrange after finding lovely hidden obstacles:cool:
You've got the idea !!!!
Reply to Amount of LED downlights in a lounge in the UK Electrical Forum area at ElectriciansForums.net
Hi All, Just wondering if anyone has come across these downlighters at all? Trying to change all the batteries and inverters for a client, i...
  • Locked
5K
Haven't seen this one before.. a string of 8 dimmable downlights in the lounge (max total load 40W) on a Hamilton LED dimmer ((LED-IT B) dim...
Hi all, I'm not sure if anyone can help but I'm looking for some advice on LED downlights and dimmer switches. First of all I'm not an...
