Does any know have a usual spacing for LED downlights? Im normally like to put a good amount (maybe a few to many) But i always work on id rather put to many in with a dimmer than not enough!
Starting a new build tomorrow and customers don't want loads of downlights. The lounge in 7 x 3. They only want to put in 8 JCC V5os. Does any one have a design method or average amount per square meter?
I tend to go with 600mm from a wall, then 1200mm between fittings. 700mm from wall in kitchens to avoid the wall units casting shadows.
The height of the ceiling can be a factor and the beam angle of the fittings. Kitchens and bathrooms would require more light than a lounge really. Whatever suits the room really.
Maybe the customers are planning on having table lamps around the lounge?
8 sounds right for that size of room.
My living room is about that size, but its extended from an existing room... so ive got 2 pendants. The original and a new one.
Hardly ever used. I wish I'd put downlights in now.
The kids like to play Just Dance on the Wii, and inevitably punch hell out of the lampshade.
Not sure what the fittings are (lms) but say 500each works out roughly at 190lm/sqm (assuming equally spaced). This would be reduced at floor level so probably towards low levels for a lounge (Think recommended is around 300 for a lounge)
Dark decoration/furniture will reduce the impact of the lighting even further.
One of our suppliers offers a lighting design service if we need a more accurate design which is really helpful so might be worth asking around at wholesalers.
In the past, I have contacted the supplier of any lighting fittings I intended to use, for lighting a particular area, and required lighting levels to supply a lighting design, the ones I used were always willing to help. I maybe worth your while to approach your supplier through the wholesaler if they could supply this service, 99 to 100% of the time they agreed, only saying this approach may help.
Most of the larger electrical wholesalers offer a free lighting design for account holders.
Yes don’t grab the first lights you see at the wholesaler because they are at the right price point. Get the photometric data and use Relux or Dialux and do a calc. Or get the lighting supplier to do if for you more st will do it for free. 1200 spacing for LED lights will most likely produce too much light dependent on fitting and task in hand. Do a calc and get it right, after all you would not make a guess on electrical loads please give it a thought, and at the end have a environment that works and a happy client.
It's a domestic lounge, not a warehouse or a football pitch. Ask the wholesaller? use design software? contact the manufacturer?
And it's already been designed for you by the client. Why would you want to talk them out of it?
So you fit fewer or more and the client says that's not what I wanted?
err on the side of a bit more light than you (or the customer) think, then fit a dimmer.
I wired a private new build last year, the spec called for 100% downlighters. As I had never done an job like this before I spent a fair amount of time researching this. The best advice I got was to allow 2 meters by 2 meters for each lamp. This seemed to work out ok. I also used down lighters that took GU10 led lamps so that the light level could be varied by using different wattage of lamp
In the old days,before the downlight fashion, a long, narrow room like this would have been adequately lit by two 100W pendants, giving a total of about 2400 lumens.
V50s are 600-650 lumens each, so a total of four will match this!
Not quite as simple as that in practice, of course. Just four would look odd, and to get anything like an even spread of light you need to make sure that the 60 degree cones of light from each fitting at least meet each other.
If you fit eight, split them up into two or three switched circuits, taking into consideration things like being able to have lights on over the seating areas, while those near the TV can be off.
United Kingdom
United Kingdom
Amount of LED downlights in a lounge
TJC1,
brianmoooore,
