the pict
Mentor
If any one like me has to do the full 18th course on line version from the NICEIC or if not here is a sample of the Challenges
A load of 750 watt 2 correction factors 1.03 and .65 what is the answer in Amps and how did you arrive at it, I will give my reasons later
Pict
stupid question. 750 watts on single phase or 3? id single i get 4.8A
750 / 230 = 3.2608695652
1.03 x .65 = 0.6695
edit
Ib = 3.2608695652
In = 6A
6/ 0.6695 = 8.9619118745
Iz = 8.96A
Pict
This question makes no sense at all, I'm not even sure that there is a question here?
What do you want calculated, what voltage is this at, what do the correction factors relate to?
I will put up a screenshot of the actual question but will need to see about copyright, but basically the example equation was presented in an obscure manner as was the wording, whether or not this is meant to be "trick question" or an error I am not sure
Pict
I would say, what is the apparent design current.
So, 750/230/1.03/0.65 = 4.87A
