Discuss Annual testing of LD2 smoke/heat detection systemstest in the UK Electrical Forum area at ElectriciansForums.net
polo1
Hi,
what happened to the Fire Detection forum????
Anyways, are any of you guys involved in annual testing of smoke/heat detection systems in private rented properties? If so, what form of report/certification are you using?
I've had a look on the NIC online certification site, but the only cert there appears to be for fire panel systems and a bit OTT for an LD2 installation.
Any advice welcome!
Cheers.
if there are just smoke alarms in the property then just use tester smoke or for Aico just press the test button and check the interconnections are operating.
There does not appear to be any formal inspection paperwork for such arrangements, just prepare a form stating what you have done including any battery changes, if applicable.
If there is a panel then you can do (a lot more) formal testing and inspection.
Thanks Richard. I'm surprised at the lack of responses as I assumed lots of these annual inspections would be getting done.
Cheers.
Sorry just seen this, agree with Richard we do a few of these and just devised are own form, basically what it is heat or smoke, it's location, was the battery replaced, is it still within it's recommended replacement date and does it function.
Reply to Annual testing of LD2 smoke/heat detection systemstest in the UK Electrical Forum area at ElectriciansForums.net
I've asked a similar question before I think and we came to the conclusion that apart from new houses and HMO's etc there aren't any rules about...
Doing work in a house the other day, and noticed they didn't have any smoke detectors... (well, one.. and it was a small 9v thing) So ive sent in...
Having a bit of a mare at the moment with a small 2 story HMO (6 single rooms with shared kitchen) which was fitted relatively recently (2016 or...
Not come across this before, so would like some help, please. I went to install smokes and heat alarm (to new Scottish regs) in a fairly modern...
Hello, my apologies if this is in the wrong section but my question is regarding fire alarms and smoke alarms testing intervals. My question is...
