A
Anonomoose
Went to a job yesterday RCD was tripping mainly in the afternoon when the hot tub timer came on. After a while of looking I found the isolator was hidden way under the decking having to remove a large hatch to get to it. (is this right? I thought they had to be accessable?) Took the front off and about a pint of water poured out as it had been mounted upside down and the drain holes had filled it with water. The bloke who fitted it had come off the incoming side of the isolator with 1.5 flex to the lighting circuit with no fusing down. So the lighting circuit was on a 40a breaker/ I dont mean to badmouth people but this is pretty shoddy work isnt it?
Anonomoose
Probably put in by the hut tub guys, who have gone on a part P short course or maybe not.
sounds like Mr. Plumber strikes again (or Mr. Electric)
