Discuss Another socket puzzle: Why the extra terminal? in the UK Electrical Forum area at ElectriciansForums.net
Fused supply for the 5 Amp sockets, get a grip
They're 2A, and the fuse is built-in.
Why would you want to cater for 2A sockets when installing a ring?
My comment was in reply to Lucien's question just above as to what you would use the 2A sockets for!
Table or standard lamps as was the norm in those days, 50s 60s 70s maybe long before people decided to change careers
The fourth terminal is indeed an output sharing the onboard fuse protecting the 2A sockets. It's intended for the rarely-seen companion unit containing a further four 2A sockets. The combination appears on the ring as one double point (one 13A socket and one unswitched FCU) but gives a total of seven sockets in two accessories. Heater, clock, lamp, TV, radiogram, other lamp, train set, spare, or whatever.
Never caught on, presumably as it defeated the idea of all plugs being identical and hence interchangeable.
Interesting piece of history there... never seen something like that before.
My gran had an adaptor from 13a plug to 2x15a + 1x 5a, so they could still use their old appliances without changing the plug.
So it doesn't fit in a standard single k.o. box?
No, it's a custom size.
Kept meaning to show you this
Is that Bath - Off - Sink for a dual element immersion? Yes please, we don't have any of those. Will happily pay postage! Pity the red indicator lens is missing but we can find something suitable.
A side note about the fireside socket fuse. The original design shown here takes a BS646 fuse so the largest you could fit was 5A, which was correct for multiple 2A sockets on one circuit. But the later style in a standard 2G plate took a BS1362 fuse so a 13A fuse could be fitted leaving the sockets poorly protected. But in practice, unless the wrong appliances were connected to 2A plugs, due to a lack of 13A sockets, it was unlikely to cause serious hazard.
Ah, maybe that's it. I thought Santon used a domed red lens but perhaps that was someone else. In that case I think we have the correct neon.
Fun! Outdoor compensation thermostat or some such, I'll take a closer look later.
Reply to Another socket puzzle: Why the extra terminal? in the UK Electrical Forum area at ElectriciansForums.net
Hello All and happy new year. Over the holiay I have changed all of my old sockets to some nice new ones and added a couple with usb sockets for...
  • Locked
5K
Hello all, Looking for help here as I've come across a strange call-out today. Bare with me here: Got a call from a customer saying they had...
Morning All I recently completed my first re wire and board change, (with help from the owner who is a gas fitter and plumper, who works with my...
