thanks to all that added constructive comments to this post !!!!!
Mines a cold one! Ariva derci
The actual name of the metal box is a Clifton/Mantel enclosure, and there are MK units available that will fit in them. Looking through the product catalogue, on page 10 found in the link below, you can see the skeleton units, one which has an RCD in it. I reckon quite easily you could use the one RCD to protect half, and RCBO's to protect the other half, or if it's a smallish property I reckon you could fit two RCD's in there and still be able to protect 8 circuits.... :)
Find it here: - Sentry 10 Way Skeleton Unit Loaded [mksentry 6001S] - £111.95 : Fastlec - Selling Brand Name Electrical Products Online, Buy Brand Name Electrical Installation Products Online
Or try this Wylex version: -
Found here: - 10 Way Dual RCD Skeleton Consumer Unit + 100A Mains Switch
Are those three phase mcbs in there?
Done a load of them, used the Wylex skeleton replacement above. You have to knock out the shelf that currently makes the bottom of old cu and a couple of the mounting brackets but its very do-able. the shelf/mounts ae spot welded in so attack it at the spots. Also make sure you got either a small hss bit or some tek screws for mounting new skeleton to case.
Yep; the centre one is definitely, the left hand one may be motor rated perhaps?
3 phase from a single phase board; (in a Paul Daniels Voice) its magic!:D
A pretty serious fopar by the manufacturer in their marketing photos,lol:D.
There must be some sort of converter in there to get three phase from a single phase board,I will have to give wylex a ring to find out!
Maybe they just didn't have enough single phase ones laying about. The one on the left side as you look at it looks like a 3 pole isolator more than an MCB. The one on the right says MCB on it, so I think it will be one of them! :D
Hi,
I replaced a few of these. Local authority type as mentioned. Go to any good wholesaler and ask for a SKELETON BOARD.
They do them with dual RCD protection as well (split board design).
You wont fit a "normal" type board in there.
Hope this helps,
Sav
Hi, have been installing new wylex 8way skeletons with RCBOs within these mantel boxs/units and there has been some snags from the housing that the new covers have gaps underneath, i.e. not IP rated. Any ideas on ensuring IP rating as covers provided by wylex do leave gaps along top, bottom and sides, especially where the columns are on either side of the unit.
Ben
