I believe that with some coaching i would get my time down to a sensible time within the limits required ....
i had thought on trying to assemble a test rig of my own ...
72-van
yes assemble your own test rig
or use your house to carry out pirs on
how far did you get through before they stopped you
was it on the 4th practical assesment of the 3 phase DB and the single phase ccu which is fed from the 3 phase
Unfortunately my house has no rcd\rcbo the consumer unit is aged probably 20-30 yrs old and is in a really ackward position ..
i have been looking on ebay to see if a local cheepo 3ph board comes along.
if i assemble a rig similar to the one they use at the college could i power it up using single ph only ??
72-van
72 Van, is there any way you could get hold of a tester? If so, would you be able to test your home/flat and on a regular basis? I used to be like you with testing but doing it as often as you can will remove a lot of hesitancy and give you confidence which is most of the battle. Those examiners want the right answers delivered with confidence otherwise they might think you guessed it..
Repetitive and correct practice of procedures won't be all that you need, but it helps because it'll free up your thoughts a bit on that orrible test rig. I know this from just having completed my AM2. The worst feeling as you seem to understand is trying to go in there imagining what you have to do and why.
I just finished that speel and my laptop showed the last few posts. Thought that counts anyway.
I bought a metrel 61557 from ebay but to be honest i could use some-one to show me how to operate it properly .Its not easy to see which scale you are using etc.
The manual is only any use as a firestarter.
The metrel does work and i think i have figured out which does continiuty and which does resistance .
but its not a tool i think i will be using very often ,i only forsee me using it for fixed appliances Pat testing as per the cop rather than using my pat tester and a break out box or similar.
72-van
Hi, the 2391 test rigs - are they all the same/similar? I'm doing my 2391 next month and I'm hoping I can get my hands on one locally to go through the testing procedure In order to learn it by rote.
Sorry dont know if the test rigs are all the same however i believe they will all have roughly the same configuration of accessories .I am sure theres a post on here somewhere with a listing .
but roughly from memory
3phase board
sub main single phase consumer unit with rcd main switch
rcd protected ring mains
radial circiut for water heater
lights one way & 2way
motor 3 phase.
