Discuss Any recommendations for 24v LED tape? in the UK Electrical Forum area at ElectriciansForums.net
HappyHippyDad
I have a 10m length to light up, this will be a skylight.
A few questions..
Any recommendations for a good quality tape that is suitable for 10m? There is a huge amount of choice on the net but lots of poor quality products.
What is the best way to wire this up with regards series and parallel?
Does wiring in parallel aid with decreasing VD?
Would 12V be acceptable for a 10m length?
LED strips should be wired in parallel.
For 10m I would advise using 2x 5m strips to avoid volt drop issues whatever voltage strip you use, or if you do use a single 10m length then feed it at both ends (from the same PSU)
I've heard good things about the quality of ArcLED Light Tape Strip Suppliers | Bespoke LED Lighting Solutions UK - https://arc-led.co.uk/
I was going to try them for lighting up a kitchen breakfast bar but it's a customer led part DIY extension and kitchen fit, so that bit will maybe be in the new year the pace things are going.
Thanks for the link Andy. I have given them a ring and they have already given me a quote which i am happy with. It's £120 cheaper than the same spec quote from LED lights - https://www.instyleled.co.uk/?gclid=Cj0KCQiA-4nuBRCnARIsAHwyuPqM5Q6FS9l1QwWdNufjEo4xHdOoaX8ky5wjoh8bTVrJkFSCY0a4uycaAjoAEALw_wcB
who I didn't feel that comfortable chatting with.
If I do go with ArcLed I'll let you know how good the overall service was and also the product.
Cheers. They seem to get good reviews and recommended a lot on other nameless electrician based internet platforms. As I say no direct experience myself.
Reply to Any recommendations for 24v LED tape? in the UK Electrical Forum area at ElectriciansForums.net
Hi all can anyone recommend and decent external 24v led tape please . The length is the issue I think at around 10.5 metres ish. Supply from 1m...
hello all. I am trying to add led strip lights to my boat trailer. I have marine grade submersible lights. I will have them running parallel to...
I'm doing a job which needs LED tape under shelving, 6 shelves with ~1.2m of RGBWW tape under. I've used downlightsdirect and downlights.co.uk...
I'm getting a little confused about volt drop and 24v. I want to fit an LED strip light. 8m of lights 7w/m. It would be easier to have the 24v...
5K
HI, My project involves installing under-cabinet lights. Wiring is there and waiting. Have any of you seen differences, gains, sacrifices by...
