Discuss Anyone use click mode switches? in the UK Electrical Forum area at ElectriciansForums.net
rolyberkin
Hi All
Bought a couple of click mode white plastic switches and changed one gang in a three gang 2 way to an intermediate. The switches do not now line up (The intermediate sits proud of the other two switches by about 1mm. I have called Scolmore who are looking into it but has anyone else come across this, is it normal as it is a different type of switch?
Ta
fit the intermediate in the centre slot. that way it will look balanced.
eaton premera seem to do the same, the switch modules infact look identical from behind just with a different rocker so that's probably why, I didn't think the two companies were related though
From the back, the modules look very similar to the old MEM Delta range. I presume that Scolmore bought the pattern from MEM/Eaton.
I've tried Click Mode, but didn't like the brand at all.
I recently fitted a 20 amp DP switch to a storage heater circuit as a replacement for an unswitched connection unit, but had to go back to replace it just a week later after the live terminal on the load side began burning (yes, the terminal connection was tight!)
I wouldn't rate Click Mode any better than the crappy LAP range that Screwfix sell.
Reply to Anyone use click mode switches? in the UK Electrical Forum area at ElectriciansForums.net
Hi everyone, just wanted to ask if any other sparks who use scolmore click mode have recently noticed a drop in the quality of their accessories...
Hi everyone :) my first post here. Quick background I'm a newly qualified installer of somewhat advanced years whose just starting out in the...
FYI --- This is a U.S. installation. I'm replacing a three way switch (the UK might more sensibly call it a two way switch??) with a Kasa Smart...
Having a rewire done with Click Mode sockets. Doubles being CMA036 (BS 1363-2: 1995)...
Morning All I recently completed my first re wire and board change, (with help from the owner who is a gas fitter and plumper, who works with my...
