I use Makita... they do EVERYTHING
Plus some Milwauke... probably better quality, pain in the backside to get the batteries in and out.
Nothing wrong with Dewalt.
Bosch, Hitachi, metabo, they're all fine really, doesn't really matter.
Do you reckon 2ah batteries will be suffice or shall I just go for the 5ah ones ?
They'll do everything the 5Ah ones will - just not for as long. So it depends on how heavily you'll be using them. Regardless of what capacity batteries you have, you'll want some spare/extra ones so that if/when you do run out you can just swap them. It's also handy if the cases have space for them.
Another consideration is the charger - it mentions a 90 minute charger, which is a long time if you've run out of juice mid job. I bought a couple of De Walt drills when they were flogging off the last of the NiCd models, and between them they have 5 batteries which recharge in an hour. They mostly do DIY, but if used heavily, a battery can be recharged before I run out of charged batteries - and I'll recharge them all when I've finished.
Which reminds me, need to have a look at the smaller (non-hammer) one - it was smoking out of the vents last time I used it :eek: It would be nice if it just needed new brushes, but ...
