Discuss Assessment equipment in the Australia area at ElectriciansForums.net
F
flukeyspark
Hi all
As Ive said in an earlier post I have my NICEIC assessment shortly, and wondered if it is essential to have amp clamps, nulling units & lock off equipment etc?..........:confused:
You will need all your paperwork, insurances etc along with copies of certs for jobs that you have done.
Then all you need is your test equipment and your brains.
You will get asked to show how to do certain tests and what the results mean, but the most important thing BEFORE any testing is proving safe isolation. And thats not with a voltstick!
Just relax. It'll be over before you know it.
Good luck!
If you have a warning sign, lock offs and a proving unit then i'm sure you would impress the assessor more but if you haven't just follow the correct procedures of isolation.
Remember that you can remove fuses / mcbs for safety if you do not have a locking device.
And you can also prove your voltage indicator on a know supply.
The assessor may want to see your tools, testing equipment, calibration certs and books such as On-site Guide & Regs book etc.
Good Luck! ;)
Warren
Reply to Assessment equipment in the Australia area at ElectriciansForums.net
Hi all. We have a 120v 20 amp circuit to an accessory dwelling with a run of about 75' of direct bury #12. The breaker keeps tripping even when...
I got a TEXT message (i dont know them and i cant find out who they are from the phone number) "Hi speaking from Indeed Are you available to give...
Morning all, We are looking at qualification requirements for inspection and testing to BS EN 60204, all of our work is past the main isolator of...
Hi there. I’m hoping for some advice. I currently run a small limited company that provides IT services, both commercial and domestic so I...
Hi all Just qualified last Monday and I have completed both initial and periodic test and inspection courses. What is the process for joining the...
