Another misworded publication. The schemes actively promote the term 'exporting'.
Tim at post #33
Exporting a PME earth isn't as simple as you suggest, as there will be a number of factors that have to be taken into account, depending on its use.
You wouldn't want to be running a 16mm 3 core swa to a customers wooden potting shed that is 2mtrs away, has no extraneous earths and has just one lighting point.
On the other hand, you wouldn't want to export to a cattle shed.
Not saying you would, but you could.
Maybe but to export it you would have to do exactly that. The fact that you could have a 'special location' downstream in some cases may not be relevant. I could have a bathroom in this downstream location but could still employ the TN-C-S derived earth.
Having a bathroom on a TNCS is fine as long as you keep to the regs but there are some special locations where a TNCS can not be used.
You will find that you have to be quite careful of the wording on this forum otherwise you get pounced on by the bully boys 🤣
@default my apologies if it came across as bullying. I'm always conscious people search this forum for advice and thought it a little dangerous to leave the word "isolator" in there. And it could have been construed to mean a "sub-main" never needs an RCD.
Anyway, nothing personal! I'm sure most of us knew what you meant, the concern was a DIY hero reading it.
I wasn't referring to you Tim 🤣
