Discuss Attach 1 double socket to CU in the DIY Electrical Advice area at ElectriciansForums.net
You can only have 1 unfused spur from any point of circuit including consumer unit that’s the regs.
I think what that reg means is that you can take an unfused spur from anywhere on the RFC, including at the CU, you are guilty of misinterpreting the Regulations Grant.
Hey George Cooke, that sounds a good idea, it would obviously be good to add the new socket to the Ring, I'm still trying to visualise that setup in my head, the job is actually in my sister-in-laws house. That being the case; would I only need to remove the live from the mcb and put it in the new socket, leaving the neutral in the neutral bar? Then run a 2.5 t&e from the new socket, doubling the live with the live I've removed and put in the socket, and putting the new neutral and earth in the appropriate bars in the CU?
Westward explain why, i was only trying to confirm what someone else suggested. You appear to be very negative, no pun intended.
Ok, I'm not an electrician. I'm looking for advice, I have a basic knowledge of Electrics, but believe with the correct advice I could do jobs like the one I'm asking about.
Whilst the forum doesn't mind giving advice to DIYers we do not extend that to step by step advice. From your posts this task is beyond your scope of knowledge. Leave it to a professional.
I would suggest you take a look at a diagram or a ring circuit so you can fully understand how it works before attempting what you intend.
It's not easy giving advise to someone when it's not clear of there level of knowledge and undertsanding.
Sorry, not trying to be negative !
Which regulation is that?
Appendix 15
Ring and radial final circuit arrangements
Regulation 433.1
Page 505 have a look at the diagram it illustrates all that you can do with regards to spuring off very good page to understand the dos and donts as I wasn’t too sure untill I seen that page.
Put in a new protective device it would require notification to building control under Part P of the Building Regulations. Connected from the existing ring final circuit it does not, that's the way of it. Do you have rcd protection.
OP is in Scotland, Part P Notification doesn't apply there
to many google diyers out there thinking they know it all just by asking questions on forums. a friend of mine had a customer thinks he knows it all does all his own wireing dosent even know how to cable size volt drop loves a jb and choc blocks apprantly
i was told his garage caught fire. insurance refused to pay out because electrics was all wrong, little knowledge is dangerous,
Appendix 15
Regulation 433.1
Appendix 15 is an informative annex, it is not normative. It shows some options that can be used for ring and radial final circuits. You can have multiple unfused spurs on the ring (you can find a few discussions about this on this site).
Sorry I’ve not made it clear what I was trying to interpret yes you can have multiple unfused spurs on any circuit but only one at each point didn’t make it clear find it easier to explain in person rather than txt
Didn't spot thato_O
OP assuming these works are in Scotland my original quotes regarding Part P were incorrect however, it is clear these works are beyond your electrical knowledge and for the benefit of your sister-in-law she needs to get an electrician in. For this reason I am closing this thread.
Reactions: 123
Reply to Attach 1 double socket to CU in the DIY Electrical Advice area at ElectriciansForums.net
