Hi guys.
I bought a pre-populated 10 way Axiom fuse board and am now told I need surge protection. I have purchased an Axiom surge protector with a little green plug on the top and a 32 amp circuit breaker. But no wiring diagram is included. Any help gratefully recieved. Garry
Did you get anywhere with this?
I have an a pre-populated 10 way Axiom fuse board that needs surge protection.
Got space for 1 module so it would be good to use this SPD which states it does not need a MCB.
Axiom make an SPD that does not need a separate MCB here:
I don't remember if it comes with the wires, but basically some 6mm for connection to Earth and Neutral is all you need.
The catch is this one comes directly off the busbar just like a MCB/RCBO - fine for main-switch and RCBO boards, but not so convenient for the older dual RCD style.
Thrashman,
Markyd,
