Discuss Back box earthing in the UK Electrical Forum area at ElectriciansForums.net
Probably a bit of a noddy question but I am bringing my TV aerial cable into the house which I have already done. Now I want to fit a TV socket to the wall to tidy it all up.
I have purchased a metal back box with a plastic TV coaxial faceplate.
On the metal back box there is an adjustable lug for an earth. Do I need to install and earth from back box to faceplate or should it be fine without?
If so can I use any wire as an earth?
Here is some pics of socket and back box
the box has thet earth terminal as it's the same box as would be used for a 240V light switch. in your case ignore it.
No need to earth backbox if you have a fixed lug so i remember reading somewhere - But what do i know i'm just an electrician apparently:cool:
My bad...as the youngsters say!
but, for accuracy...ye actually can shove yer granny aff a bus...however I would not condone this...apparently this is rather non-PC...IIRC, it was envisioned that you could indeed shove your Granny off the bus, but not your mammie's mammie, but rather yer daddie's mammie...
I do feel that this distinction is unlikely to receive judicial approval in these enlightened times ...
Reply to Back box earthing in the UK Electrical Forum area at ElectriciansForums.net
I have just checked a double outlet and it trips at 18ma. It was supposed to be faulty. Washing machine had a bad heater which got replaced but...
Hello everyone, Following on from my previous post where I received advice on taking a spur off a 40a feed (thank you). I performed the work...
Greetings, I am homeowner and looking to confirm if I will need earth boding to water pipes. There is already earth boding near Gas meter and the...
I have a known working TV and went to set it up in another building for an old chap. He has about 3 TV's already. I connected the TV to 2 seperate...
Hi, This post is about my concerns with medical IT socket outlets and want to alert you all if you are fitting them in a hospital. The current...
